Post by shriker1 on Dec 4, 2019 14:27:35 GMT -5
My two Proffieboard V2.2's keep on having random Blaster blocks and power switch presses. i have triple checked everything and nothing seems to be the culprit other then the board or os. i have been trying to find a solution on the facebook forum but i haven't found anything so far.
Possible reasons that didnt come up with anything:
Switches Faulty? - it does it with the switches disconnected as well Bad Board Wiring? - Resoldered switches and ground multiple times so they dont touch anything else Bad Recharge Port Wiring? - Pushed and pulled and tugged and resoldered to get a reaction, does absolutely nothing, doesnt trigger anything Shorting Switch Wires? - To the best of my ability i have checked all concerning wires and nothing comes up as weird. What Does The Serial Monitor Say? - Every Several seconds there is suddenly triple short power button presses, even up to six or eight presses, all at the EXACT same time, aux button does it less frequently. ill send an example soon.
has this been happening to anyone else? this has only been happening to my new proffie v2.2 boards
i should also mention that during all of the shorts i wasnt even touching it let alone near it, it just does it on its own.
Post by yodadawa on Dec 4, 2019 15:14:55 GMT -5
I have one board with strange behavior too but I need to make more tests.
What kind are the switches?
False clashes can be caused by some bass speakers, chassis design (board close to speaker) and low sensibility parameter. But false blaster blocks it should be a kind of noise in aux. Switch.
Post by profezzorn on Dec 4, 2019 15:25:53 GMT -5
I saw some of this on FB, and it's certainly a weird problem. The fact that two boards is doing it would seem to indicate some problem with the software or configuration. Could you post your config file? Maybe some pictures of the wiring?
Post by profezzorn on Dec 4, 2019 15:35:17 GMT -5
I saw some of this on FB, and it's certainly a weird problem. The fact that two boards is doing it would seem to indicate some problem with the software or configuration. Could you post your config file? Maybe some pictures of the wiring? Btw, getting more than one press from the same button in the same millisecond should be impossible because of debouncing, which has a 10ms timeout. Going from not pressed to pressed is immediate, but going from pressed to not pressed should take at least 10 ms. So if you really have 6-8 events from the same button AT THE SAME TIME, there is definitely something wrong with the software. If they are at least 10ms apart, then the problem might be something else. Have you tried measuring the voltage between GND and the button pad? Should be 3.3v when button is not pressed and 0v when button is pressed.
Post by shriker1 on Dec 4, 2019 15:44:46 GMT -5
I pulled my original serial monitor from Facebook which is still consistently happening.
unit = 0 vol = 0.50, Playing Hero/font/font.wav channels: 1 rate: 44100 bits: 16 EVENT: Aux-Pressed millis=47186 EVENT: Aux-Released millis=47361 EVENT: Aux-Shortclick millis=47361 DISPLAY: Preset: 4 RgueVdrV2 Scanning sound font: RgueVdrV2 done humstart=1000.00 Activating polyphonic font. version=2.00 swingsensitivity=300.00 maximumhumducking=75.00 swingsharpness=3.00 swingstrengththreshold=30.00 transition1degrees=60.00 transition2degrees=240.00 maxswingvolume=3.00 Activating SmoothSwing V2 Proffie Font Detected SmoothSwing pairs: 8 Accent Swings Enabled. Polyphonic swings: 16 Monophonic swings: 0 Accent Slashes NOT Detected: Accent Spins NOT Detected: unit = 0 vol = 0.50, Playing RgueVdrV2/font.wav channels: 1 rate: 44100 bits: 16 Amplifier off. EVENT: Power-Pressed millis=49053 EVENT: Power-Released millis=49242 EVENT: Power-Shortclick millis=49242 Ignition. unit = 0 vol = 0.00, Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 unit = 1 vol = 0.50, Playing RgueVdrV2/out01.wav channels: 1 rate: 44100 bits: 16 unit = 2 vol = 0.50, Playing RgueVdrV2/swingl01.wav channels: 1 rate: 44100 bits: 16 unit = 3 vol = 0.50, Playing RgueVdrV2/swingh01.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh01.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingl01.wav channels: 1 rate: 44100 bits: 16 Battery voltage: 3.56 EVENT: Power-Pressed ON millis=61369 EVENT: Power-Released ON millis=61369 EVENT: Power-Shortclick ON millis=61369 EVENT: Power-Pressed ON millis=65663 EVENT: Power-Released ON millis=65663 EVENT: Power-Shortclick ON millis=65664 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh01.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingl01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=72870 EVENT: Power-Held ON millis=73171 EVENT: Power- ON millis=73671 EVENT: Power-HeldLong ON millis=74871 unit = 1 vol = 0.50, Playing RgueVdrV2/in01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Released millis=75337 Amplifier off. Unmounting SD Card. Battery voltage: 3.71 Booster off. Motion disable. I2C sleeping.. Battery voltage: 3.73 Battery voltage: 3.73 Battery voltage: 3.73 Battery voltage: 3.73 EVENT: Power-Pressed millis=165213 Motion setup ... I2C init.. done. SWING EVENT: Swing mods Power millis=165225 SWING EVENT: Swing mods Power millis=165227 SWING EVENT: Swing mods Power millis=165228 EVENT: Power-Released millis=165406 EVENT: Power-Shortclick millis=165406 Ignition. unit = 0 vol = 0.00, Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 unit = 1 vol = 0.50, Playing RgueVdrV2/out01.wav channels: 1 rate: 44100 bits: 16 unit = 2 vol = 0.00, Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 unit = 3 vol = 0.00, Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 Battery voltage: 3.55 EVENT: Aux-Pressed ON millis=185453 EVENT: Aux-Released ON millis=185662 EVENT: Aux-Shortclick ON millis=185662 unit = 1 vol = 0.50, Playing RgueVdrV2/blst09.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 Battery voltage: 3.54 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=206944 EVENT: Power-Released ON millis=206944 EVENT: Power-Shortclick ON millis=206944 EVENT: Power-Pressed ON millis=216894 EVENT: Power-Released ON millis=216894 EVENT: Power-Shortclick ON millis=216895 Battery voltage: 3.53 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=227022 EVENT: Power-Released ON millis=227022 EVENT: Power-Shortclick ON millis=227022 EVENT: Power-Pressed ON millis=227329 EVENT: Power-Doubleclick ON millis=227329 unit = 1 vol = 0.50, Playing RgueVdrV2/force2.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Released ON millis=227339 Battery voltage: 3.53 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=249592 EVENT: Power-Released ON millis=249592 EVENT: Power-Shortclick ON millis=249592 Battery voltage: 3.52 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=267030 EVENT: Power-Released ON millis=267030 EVENT: Power-Shortclick ON millis=267030 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=269452 EVENT: Power-Released ON millis=269452 EVENT: Power-Shortclick ON millis=269452 Battery voltage: 3.52 Playing RgueVdrV2/swingl05.wav channels: 1 rate: 44100 bits: 16 Playing RgueVdrV2/swingh05.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=280784 EVENT: Power-Released ON millis=280785 EVENT: Power-Shortclick ON millis=280785 EVENT: Power-Pressed ON millis=286299 EVENT: Power-Released ON millis=286299 EVENT: Power-Shortclick ON millis=286299 EVENT: Power-Pressed ON millis=287356 EVENT: Power-Released ON millis=287356 EVENT: Power-Shortclick ON millis=287356 Playing RgueVdrV2/hum01.wav channels: 1 rate: 44100 bits: 16 EVENT: Power-Pressed ON millis=290743 EVENT: Power-Released ON millis=290743 EVENT: Power-Shortclick ON millis=290744 EVENT: Power-Pressed ON millis=294349 EVENT: Power-Held ON millis=294650 EVENT: Power- ON millis=295150 EVENT: Power-HeldLong ON millis=296350 unit = 1 vol = 0.50, Playing RgueVdrV2/in01.wav channels: 1 rate: 44100 bits: 16 Amplifier off.
Post by profezzorn on Dec 4, 2019 16:42:38 GMT -5
Color change Proffie OS 2.6CCF 2.6CCF has some changes in the button code. It doesn't look like those changes would cause this problem though. However, I would still suggest trying ProffieOS 2.9 or 3.3 to see if the problems happen there too, just to rule things out. I'd also like to see the config file. And, one more question: Have you checked the resistance between the button pads and the nearby LED pads? (Should be nearly infinite, meaning that they are not connected.)
Post by profezzorn on Dec 4, 2019 17:07:19 GMT -5
I have gone back to 2.6 from 3.3 because of this, still has the same problems When I get home I’ll test the connections If it also happened on 3.3, that pretty much rules out the changes in the button code.
Post by profezzorn on Dec 4, 2019 17:08:45 GMT -5
I have gone back to 2.6 from 3.3 because of this, still has the same problems When I get home I’ll test the connections If it also happened on 3.3, that pretty much rules out the changes in the button code. None of this explains how it's possible to have a "RELEASE" event in the same millisecond as the "PRESS" event. From what I see in the code, that should be impossible.
Post by shriker1 on Dec 4, 2019 18:02:52 GMT -5
#ifdef CONFIG_TOP #include "proffieboard_v2_config.h" #define NUM_BLADES 1 #define NUM_BUTTONS 2 #define VOLUME 2000 const unsigned int maxLedsPerStrip = 144; #define CLASH_THRESHOLD_G 5.0 #define ENABLE_AUDIO #define ENABLE_MOTION #define ENABLE_WS2811 #define ENABLE_SD #endif
#ifdef CONFIG_PRESETS Preset presets[] = { { "SmthJedi", "tracks/na", &style_charging, "Battery\nLevel"}, { "TheBalance", "tracks/StarWars.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<AudioFlicker<Cyan,DeepSkyBlue>,White,40,EFFECT_BLAST>,White>,White,200>,40,800>>()}, { "Hero", "tracks/Anakin.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Blue,Rgb16<0,3813,65535>>,AudioFlicker<White,Blue>,Blue>,White,40,EFFECT_BLAST>,White>,White,200>,40,800>>()},
{ "RgueVdrV2", "tracks/darthvader.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Red,Rgb16<45025,0,11>>,AudioFlicker<White,Red>,Red>,White,40,EFFECT_BLAST>,White>,White,200>,40,800>>()}, { "SvgNght", "tracks/Reignofvengeance.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Red,Rgb16<22546,0,0>>,AudioFlicker<White,Red>,Red>,White,100,EFFECT_BLAST>,White>,BrownNoiseFlicker<Red,White,50>,600>,40,800>>()}, { "KrssGrdV3", "tracks/Trailer.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Red,Black>,AudioFlicker<White,Rgb16<16439,0,0>>,Red>,White,40,EFFECT_BLAST>,White,80>,White,200>,40,800>>()}, { "LS6V2", "tracks/Finale.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Green,Rgb16<1662,45025,0>>,AudioFlicker<White,Green>,Green>,White,40,EFFECT_BLAST>,White>,White,200>,40,800>>()}, { "Menace", "tracks/Rinzler.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Rgb16<15138,216,64410>,Rgb16<9699,1,48793>>,AudioFlicker<White,Blue>,Rgb16<15138,216,64410>>,White,40,EFFECT_BLAST>,White,80>,White,200>,40,800>>()}, { "SstrShdws", "tracks/DarkArts.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<DeepPink,Magenta>,AudioFlicker<White,DeepPink>,DeepPink>,White,100,EFFECT_BLAST>,White>,White,600>,40,800>>()}, { "LukeROTJ", "tracks/LordVader.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Magenta,HotPink>,AudioFlicker<White,Magenta>,Magenta>,White,40,EFFECT_BLAST>,White>,White,200>,40,800>>()},
{ "SmthFuzz", "tracks/DuelofFates.wav", StylePtr<InOutHelper<OnSpark<SimpleClash<SimpleClash<Lockup<AudioFlicker<Rgb16<65535,37562,0>,Yellow>,AudioFlicker<White,Rgb16<65535,37562,0>>,Rgb16<65535,37562,0>>,White,40,EFFECT_BLAST>,White,70>,White,200>,40,800>>()}, }; BladeConfig blades[] = { { 0, SimpleBladePtr<CreeXPE2RedTemplate<1200>, CreeXPE2GreenTemplate<500>, CreeXPE2BlueTemplate<500>, CreeXPE2WhiteTemplate<500>, bladePowerPin1, bladePowerPin2, bladePowerPin3, bladePowerPin4>(), CONFIGARRAY(presets) }, }; #endif
#ifdef CONFIG_BUTTONS Button PowerButton(BUTTON_POWER, powerButtonPin, "pow"); Button AuxButton(BUTTON_AUX, auxPin, "aux"); #endif
Post by profezzorn on Dec 4, 2019 18:36:03 GMT -5
I don't see anything wrong with the config file, which means that we are now getting into more esoteric problems. However, we still need to do some measurements on the button pad to see if we can figure out if something weird is going on electrically.
I also found a potential problem in debounced_button.h which could explain why the button is getting such a quick on/off. It would only occur if digitialRead() on the pin returns HIGH and another digitialRead() right afterwards return LOW. If that's the case, it would mean that the pin goes high for a VERY short amount of time. (less than a microsecond...)
I wonder if induction could cause that? It seems unlikely, but maybe the wires driving the LEDs, or maybe the speaker could be inducing enough electrical movement in the power wire to make it read as high for a microsecond? The induction would need to be high enough to overcome the ~40k pull-up though, which seems unlikely. (50uA induced current?)
Post by profezzorn on Dec 4, 2019 18:52:39 GMT -5
I don't see anything wrong with the config file, which means that we are now getting into more esoteric problems. However, we still need to do some measurements on the button pad to see if we can figure out if something weird is going on electrically. I also found a potential problem in debounced_button.h which could explain why the button is getting such a quick on/off. It would only occur if digitialRead() on the pin returns HIGH and another digitialRead() right afterwards return LOW. If that's the case, it would mean that the pin goes high for a VERY short amount of time. (less than a microsecond...) I wonder if induction could cause that? It seems unlikely, but maybe the wires driving the LEDs, or maybe the speaker could be inducing enough electrical movement in the power wire to make it read as high for a microsecond? The induction would need to be high enough to overcome the ~40k pull-up though, which seems unlikely. (50uA induced current?) Some simple tests to test the induction theory: Does the problem occur if you set the volume in the config file to 5? Does the problem occur if you you pick a blade style that doesn't turn any LEDs on, like StylePtr<BLACK>() ?
Post by shriker1 on Dec 4, 2019 21:38:29 GMT -5
alright i found the issue. yall was right, it was a short, though i couldnt for the life of me see it. it was somehow shorting between led 1 and button 1 pad. well i resoldered the button wire to the other side of the board and so far it works, same for button 2. i swear it didnt look like it was shorting AT ALL.
Post by profezzorn on Dec 5, 2019 18:06:59 GMT -5
So I’ve checked battery positive to the button 1 pad and it says negative 658 ohms in the 2000k mode, and negative 285 volts in the 2000m mode Does this mean anything to anyone? negative ohms, that's impressive (and impossible) -0.285 volts between batt+ and the button pad seems reasonable though. The button pad *should* be at 3.3 volt, so that would mean that your battery is at 3.585 volts, which would make sense. It would be better to measure the voltage between GND and the button pad though.
Post by profezzorn on Dec 5, 2019 20:11:53 GMT -5
I measured 3.16 volt in 20 mode between ground and button pad* That is right on the edge of being weird. The voltage is supposed to be 3.3 volts. Now, it could be that your multimeter isn't very good or something, but it could also be that something is pulling down the voltage of that button for some reason.
Post by shriker1 on Dec 5, 2019 22:02:54 GMT -5
I don't see anything wrong with the config file, which means that we are now getting into more esoteric problems. However, we still need to do some measurements on the button pad to see if we can figure out if something weird is going on electrically. I also found a potential problem in debounced_button.h which could explain why the button is getting such a quick on/off. It would only occur if digitialRead() on the pin returns HIGH and another digitialRead() right afterwards return LOW. If that's the case, it would mean that the pin goes high for a VERY short amount of time. (less than a microsecond...) I wonder if induction could cause that? It seems unlikely, but maybe the wires driving the LEDs, or maybe the speaker could be inducing enough electrical movement in the power wire to make it read as high for a microsecond? The induction would need to be high enough to overcome the ~40k pull-up though, which seems unlikely. (50uA induced current?) Some simple tests to test the induction theory: Does the problem occur if you set the volume in the config file to 5? Does the problem occur if you you pick a blade style that doesn't turn any LEDs on, like StylePtr<BLACK>() ? it still happens even when the volume is turned down to 5, nothing happens when there is no led's on i should also point out that it seems to be the worst on red.
Post by profezzorn on Dec 5, 2019 22:50:36 GMT -5
That makes it very very likely that there is a short between the RED led pad and the button pad. Now, the question is how, which can be pretty tricky sometimes. If you power the board off and set your multimeter to beep mode and measure between the red led and the button pad, does it beep?
