Post by profezzorn on Feb 4, 2022 19:06:51 GMT -5
I just noticed that you have ENABLE_SSD1306 in your config. (You do have a display, right?) I have not measured power behavior with a display.
Post by profezzorn on Feb 5, 2022 23:58:27 GMT -5
I tried it with your config file. I got slightly better results with 6.x compared to 5.9. Mostly because 6.x turns off the display sooner than 5.9 does. But even after that, 6.x seems to be a few percent better.
Post by saber831 on Feb 9, 2022 21:02:28 GMT -5
I tried it with your config file. I got slightly better results with 6.x compared to 5.9. Mostly because 6.x turns off the display sooner than 5.9 does. But even after that, 6.x seems to be a few percent better. I don't have a display on this setup, Not sure why I put that in there, LOL, But would that cause drain even if no display is present? I used this config on 2 different Hilts and both died within 5 days. Would the blades being installed be the source of the drain?
Post by profezzorn on Feb 10, 2022 17:18:26 GMT -5
Yes, it would cause battery drain even if no display is present. Try removing that and see if gets better.
Post by saber831 on Feb 24, 2022 17:51:05 GMT -5
Yes, it would cause battery drain even if no display is present. Try removing that and see if gets better. I can confirm that was the issue. Once I removed ENABLE_SSD1306 Battery drain was back to what I was experiencing in 5.9. thanks for the insight!
