Post by tpharaoh on Feb 20, 2022 5:59:18 GMT -5
I put the common folder on my SD card before flashing the update, but it keeps saying "font directory not found". Also my presets.ini has settings for an old config from months ago. Maybe I'm overlooking something. My Config pastebin.com/30UsD6VT
Post by fett263 on Feb 20, 2022 6:51:16 GMT -5
When is it saying "Font Directory Not Found" and how many times? If you're positive you have the font spelling exactly the same on the SD and the folders are all in the root of the SD, check that your SD was properly ejected from you computer and check that it hasn't been corrupted. You can try reformatting your SD and reloading your fonts (make a backup of everything first of course) to see if it fixes. You currently have #KEEP_SAVEFILES_WHEN_PROGRAMMING defined. This will hold onto your presets.ini from older versions. If it's from a previous OS you'll want to remove it and start fresh with OS6. Just check out this info if you plan on keeping this define. github.com/profezzorn/ProffieOS/wiki/ProffieOS6-Keeping-Edits-When-Uploading
Post by tpharaoh on Feb 20, 2022 12:25:54 GMT -5
I gave that a shot and now the saber turns on. It appears that I get "Font Directory Not Found" if the font I'm using isn't in my presets.ini folder. Do you suggest manually putting in a preset for each font causing that message?
Post by tpharaoh on Feb 20, 2022 12:47:15 GMT -5
I updated the presets by hand and now everything is good. Thank you, sir.
Post by fett263 on Feb 20, 2022 14:06:04 GMT -5
I gave that a shot and now the saber turns on. It appears that I get "Font Directory Not Found" if the font I'm using isn't in my presets.ini folder. Do you suggest manually putting in a preset for each font causing that message? Removing the presets.ini from the previous OS would have fixed as well. With KEEP_SAVEFILES_WHEN_PROGRAMMING defined presets.ini is taking precedent over you config. Be sure to read the wiki I posted if you're keeping it.
