Post by ryryog25 on Mar 5, 2022 11:47:50 GMT -5
Hello!
I'm having some issues with the soundfont "Coda" by greyscalesoundfonts popping about 50% of the time when I stop swinging the saber. I've doubled checked to make sure I have the config.ini and smoothsw.ini files provided with the soundfont, and I've contacted Greyscale about the issue. They claimed they have not had any issue, nor have they heard any other reports of this issue. Coda is the only soundfont this happens with. I have several other soundfonts from greyscale, some from Kyberphonic, CFX defaults, some no-name ones, etc, none of them do this except for Coda.
I'm wondering if anyone has any suggestions or ideas for what might cause it, and if anyone has used Coda and it works fine for them or if it doesn't work and they have a similar issue, I'd like to know.
Thank you
P.S. I'm running a proffieboard v2.2 setup for Neopixel with an OLED, 24mm SO Speaker, and an 18650 battery. The problem persists regardless of battery charge. I'm not sure if that info is in any way useful, but I figured I should throw it out here.
EDIT: also has been tested on ProffieOS 5.9 and 6.3 in addition to 6.5.
Post by nosloppy on Mar 5, 2022 16:28:07 GMT -5
try these smoothsw.ini values
SwingSharpness=2.5
SwingStrengthThreshold=30
Post by ryryog25 on Mar 6, 2022 14:27:28 GMT -5
No dice. The previous values were 1.75 and 19 respectively. Tried it with your values and it pops the same way, also with the same intensity (I don’t know if that's the right word) I did double check to ensure that the files had saved correctly to the SD before I ejected it, and cycled presets just to make sure everything got loaded up again as well. I think it has something to do with the transition from the swing to hum because it consistently pops about the same way with the same smooth swing sounds. The one that sounds higher generally doesn't pop, or barely, but the more "unstable" and bassy sounds pop a significant amount. Also doesn't matter how hard I swing, even subtle movements will trigger a pop of the same loudness.
Post by ryryog25 on Mar 6, 2022 14:35:52 GMT -5
Hmm... there does seem to be a slight pop at the beginning of the tracks when played through the computer. I don’t know how the smooth swing algorithm works that a pop at the beginning would do anything to the end of a swing, but most of these audio files for smooth swing pop and other sound fonts don't... If that's the issue I'm not sure how to get rid of it.
Post by nosloppy on Mar 6, 2022 15:01:27 GMT -5
Sent you a PM
