Post by generalfrozen on Mar 26, 2022 8:41:12 GMT -5
Is it possible to shorten the blade just by reducing the number of LEDs in the config file?
Post by nosloppy on Mar 26, 2022 20:26:13 GMT -5
If you mean the amount of pixels lit up, yes. The number is in your blades[] array. Physical shortening is a different story of course.
Post by generalfrozen on Mar 27, 2022 4:45:54 GMT -5
yeah I mean phisically shortening it
Post by profezzorn on Mar 27, 2022 14:31:21 GMT -5
Whut? Are you asking if editing your config file will make your blade physically shorter? (Like, not just in lighting up, but the blade gets cut, and pixels gets removed?)
No? Didn't think so... So what are you asking?
Post by nosloppy on Mar 27, 2022 14:46:55 GMT -5
I think the answer here is yes. You can cut your LED strip shorter, cut your blade tube shorter to match, and then make the adjustment of how many LEDs you are left with in the config.
Post by generalfrozen on Mar 29, 2022 10:32:20 GMT -5
yes obviously I was asking if I could phisically cut my blade shorter and then adjust the number of LEDs to make it still work, sorry for the misundertanding
Post by profezzorn on Mar 31, 2022 21:32:47 GMT -5
Then yes, the answer is yes, you can totally do that.
