Post by emmeeffe on Apr 13, 2022 4:07:26 GMT -5
Hello, in the last install proffieboard doesn't work when the SD card is inside. It doesn't turn on if the SD card is in, it freezes and stop working if I put it in while already on and more strange it doesn't connect to PC when SD is in. When connected to USB it doesn't even make the usb connection sound on pc, but when I remove it the works without issue. The install has a 3mm green led wired on 3.3v port on pos and LED1 on neg with a 100 ohm resistor. I noticed that when I turn on the kill switch the led lights up, just that, with everything not working. Again if I remove the SD, everything works fine. Changed SD card and tried with one that is working on another install but same result so it's not the SD card itself. Wiring seems ok , can't see anything wrong and no shorts. here the config: pastebin.com/TwQxJgacThank you for your help
Post by profezzorn on Apr 13, 2022 13:10:27 GMT -5
That's a weird problem. I don't suppose it's something simple, like a bent pin inside the sd card holder? Is the SD_VDD pin measuring as 3.3v? Have you tried re-programming the board with a super-simple config file using the "saber" prop and see if that works better?
If re-programming works, then this is a software issue and I can work on finding and fixing it. If re-programming doesn't help, then I suspect that all you can do is to contact the seller and see if you can get a replacement.
Post by nosloppy on Apr 13, 2022 13:13:26 GMT -5
Hello, in the last install proffieboard doesn't work when the SD card is inside. It doesn't turn on if the SD card is in, it freezes and stop working if I put it in while already on and more strange it doesn't connect to PC when SD is in. When connected to USB it doesn't even make the usb connection sound on pc, but when I remove it the works without issue. The install has a 3mm green led wired on 3.3v port on pos and LED1 on neg with a 100 ohm resistor. I noticed that when I turn on the kill switch the led lights up, just that, with everything not working. Again if I remove the SD, everything works fine. Changed SD card and tried with one that is working on another install but same result so it's not the SD card itself. Wiring seems ok , can't see anything wrong and no shorts. here the config: pastebin.com/TwQxJgacThank you for your help Inserting or removing an SD card while the board has power is something you should never do. Is that what you did with the working SD from another saber? Have you re-tried that card back in the other saber? You might have just corrupted it as well by putting it in while powered. I would: - blow out the SD slot with some canned air - fresh format an SD card using SdFormatter and an external SD card reader - copy default font package onto it and properly eject it safely from the computer - POWER OFF the board, stick it in - Power on the board and see what happens.
Post by emmeeffe on Apr 13, 2022 13:18:47 GMT -5
Thanks for the answer. So no bent pin or anything that looks damaged. SD_VDD is measuring 3.3v . Uploaded a 5.9 version with a simple config but issue still happening.
Going to ask for a replacement, thanks for the help!
