Post by theproffieboardnoob on May 1, 2022 19:38:52 GMT -5
ProffieOS:28:21 fatal error: config/Jake_config.h: No such file or directory 28 | #define CONFIG FILE “config/Jake_config.h” | ^~~~~~~~~~~~~~~~~ compilation terminated. exit status 1 config/Jake_config.h: no such file or directory
Im super new to all of this and I dont know what I did. Someone please help! Thanks!
Post by kagetsume on May 1, 2022 21:03:22 GMT -5
Do you actually have a file named 'Jake_config.h in your proffieos config/ directory? That error is as simple as they get, it can't find the file indicated. What exactly did you do just before this happened?
Post by profezzorn on May 2, 2022 0:32:48 GMT -5
What instructions are you following? Are you using windows? What is your config file actually called?
Post by theproffieboardnoob on May 2, 2022 6:59:21 GMT -5
Yes its in my config file as well as named properly
Post by profezzorn on May 4, 2022 0:11:14 GMT -5
Since you didn't actually answer any of my questions, I'm going to guess what's going on:
I'm guessing that your config file is called "Jake_config.h.h", but windows is hiding the second .h
